I'm getting an intermittent alarm signal on my new RV with a CO Guardian 353 detector. If I use cabin air it self clears , it I use cabin heat it self clears. Without air it will stay on. I only have 7.4 hrs. so far, I doubt it's the new aircraft smell causing this. I thought I did a good job sealing the firewall and after sealing the firewall I added Fiberfax along with S.S. foil and sealed all that. As I wright this I'm recalling that I did not seal around an eyeball cable pass thru. I will get to that before next flight , but I'm doubting that will solve the problem ( I hope it will).
Anyone else run across an alarm in a new aircraft? I could not find any threads on this topic.
Thanks Ron
Thanks Ron
