Carbmate Rotax adaptor
yankee-flyer
has anyone been able to find the adaptor fittings and hoses (TS-400) sjhown on the Carbmate site? I'
ve checked the locations listed-- aircraft Spruce and Lockwood-- with no luck.
Wayne 120241
Carbmate
I used the Carbmate and basically followed the same setup as Tony (after seeing Tony's pictures), although I used nylon barbed fittings instead. Don't have the actual sizes handy but I was able to get the fittings for a few dollars. The carbmate hoses fit nicely on the barbed end and then I selected a threaded end that would fit inside the hoses on the Rotax. I will try and post a picture of my setup later.
Jeff
I made adapters following the advice of Tony. It took all of 5 minutes using a file and chucking the brass fittings in a drill press. Skip the expensive kit and go to your nearest Ace hardware store.
