jim miller
I am in process of installing a engine in a previously flying RV3 purchased
less engine. My airbox is a very small fiberglass with a round auto airfilter
that when installed on carb will be in front and slightly above the carbs
bottom. There is a lever and valve but no clear way that I can see to obtain
carb heat. Do RV3's use the small tube that clamps to the exhaust crossover? It looks like that when the cable for carb heat is pulled it takes
air thru the filter and not the ram air from the front opening of the airbox.
I am totally lost here any advice or photo's appreciated.
Jim Miller
Jim Miller
