I get questions from fellow pilots when they see my upper cowl removed, they ask why no carb heat box...the only answer I can come up with is that since air is drawn from inside the cowl that it's getting heated air constantly, or Bing carbs may not be prone to carb ice because of the vacumm slide configuration, although I have seen carb heat used on other light sport Rotax combinations. Anyone know the answer?
