Does anyone know which organization sells the carb heat muff and Fab part to modify the carb heat on the 7? It's a fairly simple device but seems neccesary since all you get on the stock set up is lower cowl heat and the drop in rpm is almost zero when checking. Would like to see more positive response in this Ohio winter.
Thanks.
Thanks.
