Carb / FAB Lock Washers
Rick_A
Where can I get the tab type lock washers used to mount the FAB plate to the carb?
They have a long tab section the goes over the edge of the FAB plate at the throat of the carb and little tabs that are bent down after the bolt is tight.
I have a set if you want them. I drilled the heads of the bolts and safety wired them, so I won't be needing the washers.
A significant problem with the tabbed washers are that they are not really reusable. You probably won't have to take the FAB off very often, but if you do it would suck to have to order new washers. Vans does stock the drilled bolts for this purpose. I think the part number is simply 1/4-20 drilled bolt.
