I was test fitting the newly assembled nose wheel pants. I screwed in the cap screw on one side. Seemed to go in without issue. Coming out was a different story. Somehow it cross threaded. So I’ve mostly stripped out the thread on one side of the nose gear fork.
Not sure if its better to go one size larger and tap the hole a bit bigger or helicoil to retain the original size and cap screw.
Thanks.
Thanks.
