I have a tire that is losing air. I have a 5.00 x 5 Aeroclassic Leakguard tube and this is my nose wheel. I filled it to 25 PSI on 6/10/24 and it had leaked down to 7 PSI on 6/14/24. This is after several inflate/leak cycles. The tire is on the bench, not mounted on the aircraft. When I assembled the tube, tire, and wheel halves, I inspected the inner tube visually, used tire talc on the tube and in the tire. Made sure the tube was not pinched between the tire halves. I inflated it to 30 PSI, waited for 24 hours, deflated, and inflated again. I took the inner tube out, inflated it until it felt "tight" to me and submerged it 100% in water. I could find no bubbles. The valve stem cap was off and there were no bubbles from the valve stem or where it joins the inner tube. I squeezed and wiggled the valve stem--no bubbles. I thought that perhaps there was not enough pressure in the tube to be able to see bubbles (i.e. small leak?), so I re-assembled tube, tire and wheel halves and inflated to 30 PSI. I then sprayed soapy water all around both sides of the tire at the bead and also around the valve stem (cap was off). No bubbles. Perhaps the leak is too slow to see any bubbles? I'm not sure what to try next? I've read that some inner tubes leak out through the butyl rubber? I'm at the point where I am considering buying a Michelin Airstop tube? Ka Ching!
Thanks for any suggestions!
Mike
Mike
