yankee-flyer
During the initial installation about 15 months ago I had GREAT difficulty filling the system from the bottom up. During the Production acceptance tests I was unable to bleed the brakes from the bottom up-- I could get fluid through the caliper (opening the line at the top of the caliper showed fluid flow) but could NOT get flow out through the top of the reservoir so I bled from the top down which worked OK. I tried to bleed the brakes during the condition inspection this week and had the same problem. I called in the local A&P and he could not get fluid from the bottom up with his pressure tank. We pulled forward on the pedals, rocked them, pushed, them and tapped on the master cylinders without being able to get flow out of the reservoir. HELP!!! I'd like to bleed the brakes correctly.
Wayne Moyer RV-12 120241/143WM
