I'm working on the rear window and marked the "sigma" distance off the front edge. About to make the trim cuts for the rear aft window, then will trim the front once I get the tape line on.
What are best practices for making the aft relief cuts? Drill holes in the corners and then dremel/smooth the actual cuts?
What's the best way to shape the forward edge? 80 grit paper and sand to shape with a palm sander? Then a finer series to 400 last run?
I've read so much I don't know a nice clean way to do it right the first time.
