DonFromTX
I have learned that when something don't seem right, it probably isn't. I was trying to fit the canopy frame to roll bar spacing by the plans, but something just don't seem right. They tell you to use the wood spacers between the two, but unfortunately there are three dimensions of the spacers, and they don't tell you which to use! Regardless, there seems to be quite a bit more space on the left side than the right. Hard to believe the jig to weld the frame was that far off, and I am sure it has not been bent since I got it. Is this normal to be this far off?
[/IMG].
The passenger side don't seem to be quite as far off:
[/IMG]
