I don't recall reading about the slider's rear skirt fretting the fuselage skin in the plans or on the VAF fora. Did I miss an instruction/recommendation to apply anti-chafe tape beneath the skirt?
Right side, shot thru retracted canopy.
Left side, shot thru retracted canopy.
Haven't measured the depth of the "canyons" but they are fingernail catchers for sure. I best ask the mothership where the line is between blend & fill and installing doublers. Would appreciate hearing if this is normal wear for a slider without anti-chafe.
With the number I did on the plane's first set of wheel pants, this is reason no. two I was wise to fly first and paint later.
