Canopy Skirt
Adam
;) I'm getting ready to install the canopy skirt on the plexi and wanted to know if it would be best to use some chalking between the two pieces.
Adam Silverstein
Finnish RV-8
HI Adam,
I put a very thin layer of 3M marine sealant/adhesive between the skirt and the plexi where they touch each other. I had heard of folks saying that water could seep in there, and I just felt better having a little bit of a "gasket" to keep them from working against each other. No problems after 370 hours.
Paul
I mounted the skirt dry but didn't like the looks of the where the skirt ended and the canopy began. I was also worried about rain leaking in. I decided to "caulk" the joint with a 1/16 inch bead. I had heard about Lexel and tried it unsuccessfully. It skins over very quickly (short working time). I finally got it all off and used proseal instead. Turned out ok.
Karl
