Ray Williams
Member
Hi guys, from Oz
I have had a break over our winter here and am raring to go again. After much misery before I went on vacation, my canopy frame now meets the specs so I've got the canopy ready to drill the hole for the canopy handle and get on with the Big Cut and fitting.
I have read that Step 1 is to nestle the frame into the bubble where it should find its natural sweet spot. I guess I've found that:-
However, as you can see the centre (top) bar of the frame doesn't follow the contour of the bubble; at worst there's a 5/8" gap.
My question is: when I drill the hole for the canopy handle and cut the bubble in two, will the canopy section relax and take up the centre gap?
Thanks as always from Bewildered Ray
