SmittysRV
I used the drawing below to determine the height of the canopy frame to the roll bar, which calls for the center of the canopy frame tube to be 3/8" above the roll bar top. But then I read this from the handbook:
Which one is correct?
You should try to get the frame bow to be approximately 1/8-3/16" bigger than the roll bar, all the way around. The point on the roll bar that has the most curve (10 o'clock and 2 o'clock) should be a little larger (a full 3/16") than on the top or the sides.
