I am spooked about riveting the canopy to the front bow. Two issues: Posts and builder logs advise against enlarging the #30 holes to #27 as per plans. Better to use a unibit, they say. My smallest unibit does not have 5/32 which is closest to #27. Is there one available which does?
Second issue: #27 bit is .144. As an experiment, I hand-set one of the called-out rivets (in air) and it mushroomed to .165. Is the aluminum bow strong enough to snap that rivet stem at some point before it pushes up into the Plexi? Conversely, isn't rivet setting really compressing the Plexi from the top quite a bit? Maybe the rivets have pre-stressed stems...?
I avoided the rivet issue years ago on my slider by tapping threads into the steel frame where rivets were indicated. That's a non-starter on the 12's delicate front bow.
Sure would appreciate some advice from those of you with riveted/uncracked canopies.
TIA Jim
TIA Jim
