Paris12Man
I've just completed the fiberglass work covering the front of the canopy and side areas which pivot when you open the canopy. My question is.....how do you unstick the fiberglass from the upper-forward fuselage? I used duct tape and mylar tape with wax on all surfaces that I didn't want the fiberglass to adhere to. The instructions on page 34-16 are pretty weak. They merely say to remove the pivot bolts......they make no mention of the "gas struts" which are still attached. Maybe I should have removed the gas struts prior, but the instructions didn't mention this. By loosening the pivot bolts at this point, I feel the gas struts will push the unopen canopy forward and then it would be jammed. Help help help...![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
