Zero4Zulu
On my old 6A that I'm rebuilding, the fiberglass and foam filler in the front channel inside the tip up canopy frame was done really badly, so I carved it out of the channel and found that there was very little adhesion anyway. I doubt that it was helping to stiffen the canopy much.
Question is, should I put glass/foam reinforcement back in the channel and what is the best method to construct this? Any photos?
Or will the newer sheet metal bracing fit the 6A tip up?
Thanks for any help.
Steve
Steve
