ColoRv
Hello again RV8 experts. I have yet another question. I am installing the canopy side rails and when set equal distant from the side skin at the back, 25 5/8 apart and then squared at the front with the same width and corner to corner measurement....I end up with one rail running pretty close to flush with the fuselage side rail and the other side hanging into the fuselage by an eighth inch or so. Before I drill anything permanent, I thought I would ask if this is normal. I've checked the measurements a few times and I'm pretty certain this is square and exactly parallel...but the difference from side to side at the front is a bit disturbing since that difference doesn't exist at the back. Normal? Scary? Scrap the fuselage and try again?
Also, the bow of the canopy frame is not at all the same as that of my front weldment. I assume this will change when I start applying the "controlled muscle power" that Van calls for to make the frame fit the sides, but will it change that much?
![IMG_2506_zps8be721aa.jpg](/proxy.php?image=http%3A%2F%2Fi74.photobucket.com%2Falbums%2Fi261%2Fbillshook%2FIMG_2506_zps8be721aa.jpg&hash=9d98266d0c92a0d4ed5b2f37f6be3ed6)
![IMG_2507_zpsa95774e4.jpg](/proxy.php?image=http%3A%2F%2Fi74.photobucket.com%2Falbums%2Fi261%2Fbillshook%2FIMG_2507_zpsa95774e4.jpg&hash=f285dfd97030a0bf356b2ea56a58527b)
![IMG_2504_zps3575099f.jpg](/proxy.php?image=http%3A%2F%2Fi74.photobucket.com%2Falbums%2Fi261%2Fbillshook%2FIMG_2504_zps3575099f.jpg&hash=944aec450ee6c5f101110b726c05e505)
