I have the plexi canopy in place and everything seems to fit well. I have not yet started any drilling because I am going really slow here, but one point leaves me a bit confused: The instructions have you mark and drill the front tube of the canopy frame with a #40 bit, then later you are to drill through the plexi with a #30 plexi bit through the plexi AND into the tubing.
Does that make sense? Will be plexi bit cut the #40 hole in the tube out to #30 with no problem? I am at a bit of a loss as to why the small hole to start with then enlarging the tube's hole while drilling the plexi? Am I missing something?
