Tankerpilot75
As I said on an earlier thread I am updating my interior and looking at the canopy latch system. It?s always been a little tough to latch but works a little better (on the inside) since I adjusted things a little. However, locking it from the outside is almost impossible.
After lowering the canopy (it appears to be fitting the aircraft frame okay) I try to move the outside lever to the closed and lock position. The lever from the outside doesn?t want to slide into the horizontal slot. You have to move the lever up and down until you find the horizontal slot which frankly is difficult to do on the outside. It is a little loose (moves up and down freely) but if I tighten the nut going through it and the bracket it fits into - things bind up.
Have other people experienced this issue and if so have you come up with a good solution. I want to easily lock things up when I?m at a strange field or at OSH experimental parking for a week. Fighting to get the canopy lever through the slot from the outside is not fun - it?s just frustrating!
