Someone really should put in the plans to run the wire for the canopy locked limit switch when the canopy goes in the frame. I didn?t and it took some creative work to get two wires in the slot from the front of the frame and out the oblong hole next to the switch.
Basically ran it all the way out the back of the frame then used a wire loop in the oblong hole. The loop wire I ran aft then around the switch wire then back to the oblong hole. Pulling the loop forward brought the wire to the oblong hole instead of all the way back. Thenwith a very small thin electrical tape pulled through a second wire.
But what a chore. Tried a lot of other things and ways before this worked.
