RVG8tor
There is no dimension on the plans but my canopy frame fit to roll bar seems kind of wide. It is about 1/2" gap, it is also not perfectly parallel to the roll bar. I am guessing that the tilt of the roll bar is driven by the angle the feet are that attach to the side rail. It is a QB so I can't change that. The rollers are at the forward most point in the track when in the closed position, if I muscle it I can get the frame to move a little closer but then the rollers start to move up onto the roll bar foot, which will make the canopy move up slightly.
I pulled out the latch and handle and it does not hook over the attach point on the roll bar either, I read in the instructions that you can trim the latch hook for a better fit. Mine will definitely need trimming
So is this gap I have OK. My frame to roll bar fit is ever so slightly wider at the top than the bottom, should I bend the front part of the canopy frame to make them perfectly parallel. The plans don't really address this issue.
Cheers
Cheers
