Canopy Frame Issue
bjdecker
Ambassador
Posting for a friend --
We're seeing an alignment issue with the C-01405-R & L Aft Canopy Frame and the F-01431A-FR & FL Roll Bar Frame.
At the top of the C-01405 down to a point about 16" above the Canopy Side Skin top, you can lay a straight edge or ruler flat across all three sections. At the aforementioned point, the C-01405 begins to be "proud" relative to the F-01431A Frame by about 1/16" or so. This is the case on both sides. See attached pic.
All other alignment checks are ok -- eg. Latch Link Engagement, Side skin structure, alignment tool for Canopy Frame, etc. are all perfect.
TurnerB, BillK, others seen this?
Thanks!
