aeronut67
Member
Can anyone please help?! I fit the canopy frame with the skin on the fuselage, used tape to pull the frame skin tight to the forward f771 skin and down to the canopy deck then drilled the hinge brackets. Removed the frame and installed the bushings and reinstalled the frame. there was a small even gap between the two skins so everything looked good but when I lift the canopy up,the forward canopy skin jams underneath the aft edge of the upper fuse skin and wont let the frame rotate to open.
what am I missing? Any help would be greatly appreciated.
