Question for those who have finished their canopy work. I installed the frame yesterday and centered it and clamped it to the roll bar with the spacer blocks just as instructed. The bars that sit on the fuselage canopy deck (the long, square ones) do not align perfectly with the fuselage canopy deck. In some places, they overhang by as much as 1/32" and in others, they are up to 3/32" from the edge. The instructions don't say anything about needing to bend these to achieve perfect alignment and I am not sure how I would do so anyway given it is all welded together and these are pretty strong pieces of aluminum. Did anyone else encounter this and is it an issue or is there enough overhang once the plexiglas and aluminum side sheets are installed that this variation will not matter?
Also, for the round crossbar that the instructions do instruct you to check (for consistent clearance with the panel), how did others bend this? Mine is out about 3/32 more on the right than the left. I tried bending with my hands but was unsuccessful.
Thanks!
Thanks!
