Been to forum search and checked the builder logs on this particular question but didn't see anything...
Getting ready to drill the canopy but the side bottom edges are slightly below the top of the square tubing in some places when the canopy is sitting "relaxed" on the front bow and roll bar. I put 1/8" spacers on the square tubing and when canopy sides are perched on them, I need to apply slight pressure to make contact with the front bow. My previous build experience (a slider) tells me this is a no-no.
Wanted to check with you folks to see if you can see any reason not to trim the side edges. They are so nicely finished...
TIA Jim
RV12 finish kit
RV6A O360/CS
TIA Jim
RV12 finish kit
RV6A O360/CS
