RV7Factory
Chief Obfuscation Officer
The canopy decks (F-721s) were drilled to the longerons long ago, but now that the fuselage is riveted, they are a bit tight going back on. If I start clecoing them to the longerons at either end, I have to apply pressure laterally to get the holes to line up. With the first few holes in one end alinged the displacement of the holes worsens as you go along with the last hole off by about 1/4-3/8".
By applying pressure I can cleco them both on, and they lay nice and flat, but I don't like forcing anything into position.
I am inclined to just keep moving along, but I am curious if anyone out there in RV-land has encountered the same thing and what if anything you did about it.
