Canopy crack 7A slider - how to fix
N787R
Active Member
I have 3 hair line cracks. They start from rear skirt and travel 1-2 inches forward.
I drilled holes at the end of cracks to stop it going any furthur.
Q1 : What else can I do to make sure it does not get worse?
Q2: What is the best way of covering it up like it never happened?
Ben
Weldon 3
Not sure you can do anything to make it like it never happened. You stop drilled the cracks which is half the battle. The other half is to use Weldon 3 (available from ACS, etc) to glue the crack. Weldon is a very watery plastic adhesive that will wick into the crack. It is very strong stuff.
