Scott, Your fix is easy. All you need to do is reinstall new bushings with an undersize hole and redrill with the canopy frame in place. OR start with a new set of blocks, and using a short hinge pin like I did and then drill the 2 mounting holes again, with the canopy frame in place. Problem solved for under $10 and under 1 hour.
-Jeff
In the end, I think mine came out great. I'm very happy with it, fun flying.I think I need this explained again. I'm missing something.
I just did this and I accidentally took too much off. The center part is at 0.15" just over an eighth of an inch and now I am really upset. Has this happened to anyone else and what do you suggest I do so it doesnt look like crap?
- Matt
After reading these posts and I do have a good line on the front edge, but the tip up leading edge sits proud of the front deck skin by about the skin thickness.I have to pull down with several strips of duct tape to get it nearly flush in the curved portions. Is this normal? I can't see or feel any interference under the skin. Also I haven't seen any reference to the .032 gap for the tip up clearance dimensions. Where is that at?
