BuckWynd
Everything electrical in my wings has wing root connectors. That will make it easy to install the wings after everything is painted someday. I am installing a Garmin G3X system, and the autopilot roll servo (GSU 28) is in the right wing.
I'd like to use a connector for it at the wing root. Obviously, the CANBUS wires are very particular about having good shields.
Has anyone successfully installed a shielded, two-pin connector in a Garmin CANBUS line, and if so, what did you use?
Thanks in advance!
Thanks in advance!
