The New Zealand situation.
Interesting you Canadians should bring this up. We have a similar situation in New Zealand. While LSA is recognised in New Zealand, factory built LSA is lumped in with Type Certified, so you have to have a full PPL to fly it, can?t do any of your own maintenance, need a LAME to certify it every year, Annual Review of Airworthiness, no modifications, bla bla.
Experimental LSA is sort of recognised, but simply lumped in with experimental amateur built.
We have a microlight category here which is the fastest growing segment of aviation. A microlight must be no more than 1200 lbs MAUW, 45 kts or less stall speed and no more than two seats. The microlight movement is self regulating with their own pilot and maintenance licences, a sensible medical requirement and you can do your own maintenance and modifications are less of a problem.
From what I hear our CAA are really grumpy if anyone wants to build something as a microlight that complies with all the requirements, except that like the RV12, has a designers gross weight off more than 1200 lbs.
One thing I noticed when looking at the RV12 was that Van?s requirements when purchasing were rather onerous, basically requiring purchase of the full kit (due to the ATSM certification system for LSA?s or whatever it is). This a) makes it very expensive and b) locks you into the TV screen instrument set up and engine and prop combination, and possibly even buying the 912S from Vans. All of this is not required for the New Zealand microlight rules, so the whole exercise becomes self defeating.
I understand the Canadian microlight category is not dissimilar to New Zealand?s. What we probably need is Van?s to produce a non-USA RV-12 kit that is more flexible and has a reduced gross weight to allow it into the microlight category.
Going Experimental amateur built is the other option, but under our rules set up, really undermines the value of the finished product and lessens its usefulness. One is better off choosing an RV9/7 etc. or in my case, I chose an RV6.
I?d welcome any comment, particularly about the possibility of a ?foreign version? from Vans.
Andrew.
