Mike:
When do you need a ferry pilot?
What do you need to ferry?
Does it have to be a Canadian pilot? (Does Canadian registered aircraft need a Canadian pilot to clear US Customs?)
I am a high time RV Pilot (>2,800 hours in RVs), U.S. Commercial Pilot with 2nd class medical, FAA Licensed A&P, EAA Tech Counselor, Pittsburgh EAA Chapter 45 member, Retired DAR, and located 14 NN away from KFWQ based at KVVS.
IF you are buying a Canadian built RV, look into what will be necessary to get an airworthiness certificate before buying it. Sometimes there can be issues getting a US airworthiness certificate in the amateur built experimental category.
