HighSchoolBuilders
Hi All,
I have a Dynon Mode S transponder, and understand that I can't use mode S unless I put in a HEX code and register it with the authority.
I would like to ask if there is a way to downgrade the transponder to transmit Mode C signal instead of Mode S.
The registration process here is a nightmare and a lengthy one. I am not allow to taxi unless I have a transponder, but I can't use my transponder without a HEX code, hence no transponder, no taxi.
Would greatly appreciate if any transponder guru can share your thoughts.
Thanks!
Hank
Thanks!
Hank
