Looking to use Milspec (camlocks) on top cowl firewall edge only. I currently have all hinges and find to install the top cowl you must interlock both the horizontal and the vertical (firewall) hinges simultanously which requires all sorts of contorsions to achieve.
So the thought was camlocks on the vertical (firewall) edge, now, do the camlocks protrude too far below the fibreglass and thus I would have the same problem interlocking the horizontal hinge while trying to lower the cowl as the camlocks would stop the cowl at the curved section.
Hope I explained this clearly
Peter
Peter
