If you're referring to the attachment along the split line between the top and bottom cowling, then putting the camlocs above the split line is more common than below, and there is a good reason for it. With the camlocs above the split and the flange being part of the lower cowling, the assembled cowling will shed water (think roof shingles). If it's the other way around, then water will seep down through the split and into the cowling. Not necessarily disastrous, but undesirable.
