So I completed my RV-10 fuel tanks, specifically for the left tank, I gave it about two weeks to cure before doing the balloon test. Filled the tank with air and inflated balloon, did the soap water check for leaks. All good at this point, no bubbles. Let it sit for 3 days and the balloon didn't change or otherwise lose air. Did not do the manometer test that many suggest. However, I did add about 5 gallons of car gas to let slosh around in different orientations. Big however, I did not open a vent. I began noticing some leaks around the rear baffle on the bottom corner of the outboard rib (directly below the fuel cap). Being somewhat perplexed and turning the tank over and seeing other potential leaks, I then popped the fuel cap lid and heard a 3 sec pssss. Ah, tank was pressurizing itself from fuel vapors. At that point all leaks stopped. Let it sit for a day in different orientations ensuring it was vented at atmospheric pressure, no leaks. Since it is easy access through the fuel filler, I plan to add more proseal at the corner joint where the pressurized leak was observed, but is there anything else I need be concerned about given the above scenario? Should have thought about venting the tank prior to adding gas, hope I did not compromise the overall integrity. Thoughts???
