Vans has all their panels as well as the structure behind them (RV-12 not included) available on their web site under support. They are 3D CAD files so you will need to use your EAA membership to install Solid works so you can take advanage of this very accurate information.
I have quite a few cutouts available. Round. Round with provisions for kohlsman knobs or VSI. 3 ATI. And even versions for when using wedge lights (nulites etc...). I even have switch and circuit breaker cutouts with the index tooth. Same for various ELT heads, USB charging ports and ACS ignition/start switch. I use laser cutting so my details don't worry about minimum router diameters but can be radiused through a corner trim command in CAD.
