JackinMichigan
I am at the point where I am finishing up the FWF attachments.
My problem... I want to route the cables to finish up the engine compartment while my last project is the instruments and panel. I have an Aerosport Products panel.
Those cables give me a problem. As with all "choke" type cables they attach through the I/P in a permanent way, and to remove the panel you have to pull all the cables out from the engine compartment.
I plan on making solid brackets that solidly attach with screws (maybe AN3 size) to the I/P from behind. When the panel comes out, I disconnect the screws and the bracket (and cables) fall away allowing me to remove the panel. I plan on using the standard location of the cable outlets on the panel only opening them up so the knobs on the cables can pass thru.
Does anyone see an issue with doing this?
