I have the matco brake valve to install. I need a cable nut for the arm.
This one looks right:
www.aircraftspruce.com
05-16245, the last one on the list, seems best but not sure if it is long enough to fit the width of the arm.
Anyone know if this is the right thing?
![www.aircraftspruce.com](/proxy.php?image=https%3A%2F%2Fwww.aircraftspruce.com%2Fcatalog%2Fgraphics%2Fc%2Fcableendb1.jpg&hash=f8aeeffe0a336c8e5c41b9aa8336a906&return_error=1)
Cable End B Nut | Aircraft Spruce
Cable End B Nut This universal NAP assembly will eliminate bent or smashed push-pull cable ends and get a strong hold at the same time. The cable end lays in a machined channel at the bottom of the screw hole. ...
