I have a fairly substantial amount of cold air leaking into the cabin behind the seats. It seems to be coming from around the ends of the spars, most likely from the gap around the gear legs. First noticed it when I reached down between the seats around the spar carry through channel. It seemed to be strongest and most concentrated around the centre of the aircraft but I was able to trace it to each side. As I didn't build the aircraft it's a bit difficult to visualise the path it might be taking. Is there something missing? Or do I just need to work at blocking the gap (wherever it might be) and perhaps installing fairings at the gear leg/fuselage interface?
The heater had been struggling to keep up during our southern hemisphere winter (which is mild compared to most of the US). I could feel the cold drafts coming in where the canopy frame doesn't seal properly but now realise they are minor compared with the blast behind the seats. I now have the canopy seal kit which wasn't available when the aircraft was built but haven't had a chance to install it yet. I'm sure it will help but isn't going to solve the problem.
Jack Moore
Jack Moore
