Zircon only refers to a brand or type of grit paper.
It is basically 36 grit abrasive.
When doing the glass, I would always recommend a variety of coarse grit abrasives - mostly on long blocks.
Tip Time:
Make up the following -
18" x 3 x 3/4 MDF or good ply. Go to Home Despot or similar and look at belt sanding abrasive - it comes on a stout fabric backer.
Seal the MDF/ply with rattle can paint - nothing fancy, then use a branded contact adhesive to stick the fabric to the block.
I use 36/60 (double sided) on one block and 60/80 on the other block - never finer.......
If you are doing profiles, such as the canopy, use a piece of 4 x 2 around a foot long, profile one side using a plane to what you want the fillet to be and use 60 grit paper this time, again contact adhesive on.
Why so coarse ?
Because you are using it in a slow forward motion much like a file - the purpose is to remove material in an even manner, or to prep the surface as a good key to take adhesive, or epoxy.
If you are working towards a final surface, once you are close - then go in with finer grit paper to proceed towards a finish.
