C1 Missing On Thumb Drive
BH1166
My USB drive with plans for 6/6A is missing Section C1, which per table of contents, my nose wheel, pant etc. drawing/part#s. I have 1990 plans built 6A per my logs, First flight 1992. Can someone help me out.
C1 rev 5 shows a stiffer axle and a nut for bearing preload adjustment
I'm guessing C1 fell off the list of drawings for 6A and 8A in 2019 when it went to rev 6; the list of applications in the title block dropped the 6A and 8A.
In addition to not being on the OP's thumb drive, C1 is not in the Van's store at My Aircraft / RV-6A. C1 rev 6 is on my RV-7A thumb drive and Van's support says it is the latest. C1 rev 4 is on my RV-6A thumb drive implying I purchased that thumb drive before 2019.
Attached is rev 6 to show a stiffer axle and a nut for bearing preload adjustment were incorporated at rev 5, one day before rev 6. The nose fork part number did not change with the new axle. One could also use the Matco axle or the Anti-Splat mod.
  • C1 with new axle and elastomer nosegear r6 of 2019.pdf
