andrewbutler
Member
Hi,
I am in the process of preparing my RV7 "canoe" for priming and riveting. The plans to say review section 5E and diagram 5-4. This refers to countersinking sandwiched (in particular .032) skin. There are several placed in the the canoe where skin is sandwiced so can anyone give advise on the below three sections:
1. The front 772 lower skin. Would it be better to dimple the top skin, cs the second and leave the longeron underneath ountouched.#
2. The aft skin has two rows of holes where it connects to the centre section. What about C/S ing the forward row of holes on the sandwiched skin, leaving the underlying 706 bulkhead alone and finally
3. The main longeron has two skins above it. Should I simply countersink the sandwiched skin that lies against the longeron and leave the longeron untouched.
Common practise appears to be dimple all the skins and c/s the longeron, even though the plans imply that it is okay to c/s sandwiched skin........
Others any thoughts?
Andrew Butler
RV 71700
Galway, Ireland.
Andrew Butler
RV 71700
Galway, Ireland.
