RVG8tor
I am looking for opinions on my method for connecting wires to the buses. The top two rows in the photo are my main buss breakers. The big nut at the top is the 6 awg wire from the battery relay, it is just the lug now. The short wire labeled P13 is how I connect the top bus bar to the middle bar. This wire is only 8 awg, I am not sure this is OK since the main feed is a 6 awg wire. I am using 6 awg based Aeroelectric DWG, but I am guessing I could get away with 8 awg, it is only about 3 feet from the contactor to the bus. I will run wire from the 8 awg wire where you see it clamped, to the diode on the black heat sink then to the bottom bus bar which is my essential bus.
Please give me feedback and pointers, I want to know if I am on the right track. This panel will sit by my right leg along the sloped console of the RV-8A. I used a castle nut because for a temporary install it is easier to work with. I am using a AN4 bolt because that is the smallest size lug I could find for the 6 awg wire.
