Does anyone know of a good site that profiles the entire cowl fitting process?
These first few cuts have me confused and scared. I'd like to see a detailed build log to put my mind at ease.
Phil
My log on those sections aren't very verbose. I made several mistakes that I'm fixing now. I found those directions confusing too. My forward, outboard corners don't fit well because of how I did the first cut. I'm recontructing them this week.
Also, I would use a 1/4" spacer instead of the 1/8" spacer called for in the plans. What I didn't realize was the tension i had place on the spacer.. When I removed them them top didn't have enough clearance. If I used 1/4" spacer, the gap would just be about right.
I'll be visiting Brad at sheppard and flying with Alex this weekend. Too bad you weren't closer, or I would stop by.
Do you guys have an older pink cowl or one of the newer grey ones? Mine is grey and looks to be almost blemish free on the outside. I'm actually optimistic I wont have to spent much time finishing the exterior surface compared to the pink parts.
