Kevin Horton said:I'm not aware of anyone that has put one in an RV-8(A).
As far as I know, the BRS for the RV-7 has never been tested, so it is a bit of an unknown how well it will work. The loads would be quite high if the chute opened at RV cruise speeds. If the chute were opened following some sort of in-flight failure, it is quite possible that the aircraft will be coming down hill and the speed would be even higher. Would the chute and aircraft structure be able to withstand the loads, or would they fail?
The rate of descent of a Cirrus under the chute is up to 1500 ft/mn according to the Cirrus POH (6.2 MB PDF). The Cirrus seats are specifically designed so that the occupants are not subjected to dangerous loads during an impact at 1500 ft/mn. What would happen to the backs of the occupants of that RV-7 if it hit the ground at 1500 ft/mn?
As a point of reference, the BRS on the Cirrus is only cleared for use at 135 KIAS or slower. RVs are flying at much higher speeds than that the vast majority of the time, except when in the traffic pattern. BRS deployment at typical traffic pattern altitudes might not leave enough time for the chute to deploy and then arrest the aircraft's rate of descent before it hits the ground.
My BRS 1800 in my 7 is rated for a maximum deployment speed of 175 mph. Sink rate would result in a 15 mph collision with the ground, landing gear would bend. Deployment over water would be worse because the landing gear would not be able to absorb the energy.
All Cirrus deployments over water have resulted in neck and back injuries.
My seat cushions have the high density energy absorbing (NASA foam)
available from: Classic Aero & Designs Oregon Aero.
Possible Reasons For Deployment:
Mid-air Collision
Single Engine? at night or in IFR
Loss of Power? over water, canyons, trees
Stall/Spin in the pattern
Recovery takes more altitude than a parachute!
Loss of Control? jammed control systems, aircraft fatigue
Structural Failure
Very rare, but usually a poor outcome (happend to Vans RV-8)
Pilot Incapacitation
Your passengers may be thinking about you.
Pilot Error? technique, planning, judgment
It's usually the pilot (at fault) -- as the stats show.
Hope I never need it.
This would be my concern with a BRS in a high performance RV such as the 8 - less so the -9. The existing models out there do not have the same performance envelope as many airplanes out there. Exceptions are the C172 and C182 systems, as well as the BRS systems for LSA, one of which was successfully deployed at 160 kt during flight test. So, the BRS would work in the -8 for engine out, pattern stall/spin and other types of lower speed accidents, but might not work for higher speed loss of control accidents due to the speed of the -8.Kevin Horton said:As a point of reference, the BRS on the Cirrus is only cleared for use at 135 KIAS or slower. RVs are flying at much higher speeds than that the vast majority of the time, except when in the traffic pattern. BRS deployment at typical traffic pattern altitudes might not leave enough time for the chute to deploy and then arrest the aircraft's rate of descent before it hits the ground.
Do you want something that you are confident will save your life, or are you just looking for a placebo? If the system has not been demonstrated to work under a wide range of conditions, then it is no more than a placebo as far as I am concerned. Worse, the presence of the BRS may suck you into situations that you wouldn't otherwise put yourself.
I'm going to respectfully disagree with this, as it pertains to pilot rig chutes, for a couple of reasons. First is the well-documented, well-debated question of whether you could get the canopy open and get out of many RV models in the first place. Flop over 4s, probably. Tip-ups, forget it. Slider 6/7/9, maybe, maybe not. 8s, probably.Bartman said:Without a doubt there are very few "in flight" problems that a parachute (BRS or a pilot rig) cant solve.
Onboard fire would be a good situation for use of a personal parachute, but bad for a BRS.sprucemoose said:There are certain, limited circumstances where a pilot rig will allow you to live to fly another day. Sean Tucker's recent incident is a good example. But to say that they are a cure-all is misleading.
The only reason I see to use the Jiffy Pop (as we have started calling it) in an engine failure situation are over water, hostile terrain or in an area where I have few landing choices, e.g., I can pull the chute over a small parking lot or try and land in a neighborhood. If the engine quits and I'm over reasonably decent terrain, I'll land it. For me, the parachute is for use when there is little to no chance of a landing without serious injuries - pulling the chute will damade the airplane at the least and landing under the chute can cause injuries of its own.jcoloccia said:As far as engine failure I'd be willing to bet that the vast majority of pilots would have a better outcome flying it to the ground than yanking the chute. I have no data to support this other than many pilots I know have had an engine failure at some point and they were okay vs. only a couple I know that had a bad day. Maybe the chute would have saved them...I don't know.
OK, who's gonna be the first to... to put an ejection seat in their RV? Pull the handles and it blows the canopy and pushes you out of airplane. Couple of small rocket motors in a lightweight aluminum chair pushes you out about twenty feet from the airplane where you can then pull your chute.
"Hello, Mythbusters ? We'd like to borrow Buster for a little experiment ... what kind? Well, we're going to shoot him out of an RV with a parachute ... no, not that kind ... this afternoon? We'll be right over"mdredmond said:The better question is who's going to be the first to test it. Go ahead, I'll wait for you right here...![]()
designerX said:Thanks for all the helpful replies ... Also... If Vans fuse kit came with a BRS installed I wonder how many of the anti-BRS individuals would remove it.
Have fun and fly safe.
Stan
the_other_dougreeves said:If the engine quits and I'm over reasonably decent terrain, I'll land it. For me, the parachute is for use when there is little to no chance of a landing without serious injuries - pulling the chute will damade the airplane at the least and landing under the chute can cause injuries of its own.
More than you might think. I removed the air bomb from one of my cars as I don't like the idea of a pyrotechnic device only 12" from my face.designerX said:Also... If Vans fuse kit came with a BRS installed I wonder how many of the anti-BRS individuals would remove it.
Stan
Formula 1 cars weigh a minimum of 605kg (1333 lb), have engines that make 750Hp plus and provide incredible crash protection. Needless to say, everything that can be built from composites is. The cars are normally under 500kg and use ballast to bring them up to minimum weight and provide better weight distribution.designerX said:Have you ever noticed what race cars do have in regards to safety? It may be hard to fit all those steel roll cages, huge seats and restraint devices in an RV unless you want to double it's weight.
Hmmmm... I'd tune in for that show. You know, I bet Mythbusters could make a killing selling copies of that mold she made for the aircraft lavatory eposide!pfactor said:Originally Posted by the_other_dougreeves
"Hello, Mythbusters ? We'd like to borrow Kari for a little experiment ... what kind? Well, ...
This could start a hole new thread but the BRS issue is kind of like the one I hear on the car forums. Small, nimble car, with good brakes that can avoid an accident or the big, slow, tippy SUV/Pickup that just plows over whatever gets in its way. (BTW, I have both and would rather drive my small car, even with the track suspension. The truck is just a big slug waiting to cream somone.)designerX said:Have you ever noticed what race cars do have in regards to safety? It may be hard to fit all those steel roll cages, huge seats and restraint devices in an RV unless you want to double it's weight.
I hope you sold your "air bomb" on eBay... there is a huge demand for those dangerous things.![]()
