Broken off ACS 264 ignition key... options
ERJDriver
Anyone have a solution? Key isn't fully broken but slightly twisted and most places say they won't touch it to cut a new one.
I know ACS has them but they're 10 weeks out
Goto a local locksmith. We have a lock and safe small business here in Clermont. It is a basic filing cabinet key. Most locksmiths can read the depths and recreate it with minimal work. I would avoid the big box stores and they will just toss it in a machine.
That's the plan, once I get back in town
Maybe you can share the number that is on the key, perhaps someone has the matching number and can lend you a key till your replacement is ready.
I know I have got an spare one.
What he said. I took a 40 year old ignition key in and the guy made a new key in 5 minutes based on the depths and did not use the original to make a copy.
I lost the set of keys for my Andair locking gas caps somewhere in my build shop. When I moved the RV-10 to the airport for final assembly and fuel tank calibration, I called a local locksmith. He came out, picked the lock open, then took it to his shop and made new keys for me. Took a week or so because he had to order the blanks. He was not concerned about it being for an airplane. I did find the original set of keys last year when I sold the house and cleaned out the shop underneath a set of shelving. No locking gas caps on my RV-9A!
Agreed. A real locksmith, versus someone in paint department covering in hardware, can measure depths at positions and create one from scratch.
When you get the new one make a few copies. I have the one I use, one in the airframe logbook, one in the engine logbook and one hidden in an inspection cover for a lost key while away from home possibility.
I wonder how many keys would be found at Sun 'n Fun and Oshkosh camping areas with a metal detector.
