my experience
for what it's worth, I find the 'breakout' to be uneven. ( 9a )
if even a drop of oil leaves the engine room, it seems to run down the fork and lubricate the washer, thus reducing the friction.
if you want to 'check' the breakout, you can lift the nose wheel ( ballast the tail, or whatever works) and throw a strap around the pant in line with the axle.
pull on the strap ( 2" webbing works well) and you can check if your breakout has changed, without full disassembly of the pant.
No fish scale? put a block of wood across a bathroom scale, and push or pull on that. it's gonna be within a pound or two.
mine tends to be 28 lbs to starboard, and 25 to port for some reason....consistently.
just one reason that it's not that great a damper.
as others mentioned, it may not be the only source of shimmy; many seem to be fans of improving the bearing, tire balance etc.
