WingnutWick
I know this seems basic but I'm on a time crunch and got myself in a pickle trying to make a "quick" fix to a brake compression fitting that was starting to show signs of leaking on my RV-10's master cylinder. I disconnected the line and my plan was to just replace the 1/4 sleeve but I noticed, unlike my 8 which has stems the line goes onto, this one had brass inserts which I hadn't seen yet. Attempting to pull the sleeve off I was unable as it was compressed around the line/insert pretty well, so I just cut the line off just above thinking it would be an easy to just take the inset out and put it back in. Turns out getting the 1/8 insert out and especially back into the slightly smaller thank 1/8 line was nearly impossible and I totally destroyed it in the process with pliers. Of note the insert in thew pic was originally longer - I cut it trying to get this to work.
Questions are:
1. Is the insert type of compression fitting standard? Or is it normal to have a stem already attached to the 90deg fitting coming out of the mast cylinder?
2. I need to get this back together ASAP - can someone confirm the part numbers for what I have or recommend a different fitting if the brass tube insert style is not standard.
3. If it is standard, is there a technique to get this into the pretty rigid high pressure nylon brake line?
Thank you!
Charles
Questions are:
Thank you!
Charles
